Results 1 to 4 of 4
Thread: copy() function does not work
    May 2004
    525
    Default copy() function does not work
    Hi you all. I have what seem to be a simple task but it does not work. I want to copy images dynamically . I keep getting this error:
    copy(../../images/merchant/particulars/208/) failed to open stream: Is a directory in some/filepath on scriptname.php line x.
    The path above is the destination folder which i know exists and the image i want to copy resides somewhere like this:
    ../../images/merchant/particulars/652/imagename.jpg.
    here an extract from my code:
    		$dir = '../../images/merchant/particulars/'.$copytothisstore.'/';
    		$image_to_copy = '../../images/merchant/particulars/'.$copyfromthisstore.'/'.$copyvalue;
    		if(file_exists($image_to_copy)){
    			//chk if there is a folder created for this store if not create it and copy
    			if(!file_exists($dir) || !is_dir($dir)){
                                       mkdir($dir, 0777);
    				   chmod($dir, 0777);//force 777 rights
    				  //copy the image
    				  if (!copy($image_to_copy, $dir)) {
                                             echo "failed to copy $image_to_copy\n";
                                       } else {
    					  echo"all is well!!";
                           } else { //if the folder already exist just copy
                             chmod($dir, 0777); //force 777 rights
                            } else {
    "...men are that they might have joy."
    Nephi
    May 2004
    525
    Just had an epiphany. The answer is copy('images/249/images.jpg','images/230/image.jpg'); not copy('images/249/images.jpg','images/230/');
    Nephi
    May 2004
    525
    Full corrected code posted
    $dir_to_make = '../../images/merchant/particulars/'.$copytothisstore;
    $dir = '../../images/merchant/particulars/'.$copytothisstore.'/'.$copyvalue;
    if(is_file($image_to_copy)){
    if(!is_dir($dir_to_make)){
    mkdir($dir_to_make, 0755);
    chmod($dir_to_make, 0755);
    //copy the image
    if (!copy($image_to_copy,$dir)) {
    } else {
    } else {
    } else {
    echo"$image_to_copy does exist!";
    } else{
    echo"$image_to_copy does not exist!";
    Nephi
    3,068
    hahah, I was wondering what was the problem. Also I think some shared host servers recommend 775 instead of 777.
