Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Power Supply or Video Card?
    Oct 2006
    9,074
    27
    shouldnt have a generic PSU. Work out a way to change that even if its not it that's the problem. Though it likely is a PSU issue. You can monitor the system voltages with AIDA64. Maybe it will record it right before shutdown. You can check the GPU usage where it shuts down and look at other info for clues.
    You assume all risk for your use. © 2006 Azix Solutions.
    All rights reserved.
    Dropbox: http://db.tt/8qVS35lo
    Oct 2006
    703
    Quote Originally Posted by MaxFactor1 View Post
    Mi waa di man buy a good power supply caw if him parts bun up him back at square zero...
    We all agreed that the better the power supply the more stable a mid to high end computer system will be, but, even if he purchase the best one on the market today his computer will shut off until he service that graphic card. Also be reminded that whenever the card shut down it's the VRM's that fail. these are some small transistors on the power control area of the video card.
    Gigabyte GA-A75-UD4H .Crucial Ballistix Sports 8Gig ddr3. Llano A8 3870k Quad Core APU. 22" Acer 1680x1050 LCD monitor + 32'' 1080p LCD HDTV. Sapphire Radeon R9 270X Vapor X video card. Mobile: Galaxy Note 4.
    Oct 2010
    i think its the power supply thats worn out and the summer heat causing the components to further lose efficiency he should get a premium unit over 600watts
    Jul 2009
    3,700
    18
    i agree with all those who said a psu prob i had a similar issue with my previous rig (yeah i had in a generic 700W) prob was solved after i got an Antec psu
    896
    I say the PSU for the mere fact that it happens under load. Can you post a pic of the PSU specs? How many amps on the +12v rail?
    AMD FX 8150 @ 4.2Ghz | MSI 970A-G46 | 8GB DDR3 Corsair Vengeance | XFX Radeon 6850| 19" Acer AL1916W | Western Digital Raptor 160GB 10,000RPM 16MB | 2 x Seagate Barracuda 1TB | 1 x SAMSUNG 750GB | CoolerMaster HAF 932 | Cooler Master Extreme 2 525 | Klipsch ProMedia 5.1 THX 500Watts
    Jan 2006
    3,986
    Quote Originally Posted by wheelman View Post
    Well the thing this psu has been working with it for the several months. So what would cause it to just stop out of the blue like that? One of them has 30A and the other has like 33 or so and both of them are not powering it one of which as I stated use to power it.
    Intel i5 2300, Gigabyte Z68XP-UD3, 12GB DDR3 @1600 MHZ, XFX 6870 2gb (Stock). All Stock
    For in much wisdom is much grief, and increase of knowledge is increase of sorrow | If you love something let it go, if it comes back to you its yours if it doesn't, it never was.
    896
    I'd say do the stress test everything independently and see which one fails. So run tests on processor, memory, gpu, hard disks etc. After all even though its been that config for several months, electronics can develop a problem just like that.
    I think everyone at some point has turned off their system and then come back to it suddenly giving them a blue screen or not turning on or whatever. Something can happen at any time...divide and conquer I say, it can't hurt.
