Mobile Device: Google/Lg Nexus 4
Desktop: MSI 785GT E63 Motherboard/AMD Phenom II 555 X2 (Unlocked to B55 X4) AM3 CPU Cooled by COOLERMASTER Hyper 212 Plus/EVGA NVIDIA GTX260(dead after 4 years of ardent service. R.I.P./2 x 2Gb OCZ 800MHZ DDR2 Ram/Corsair TX750 PSU/NZXT Tempest Case
You assume all risk for your use. © 2006 Azix Solutions.
All rights reserved.
Enter https://www.playfire.com/ps3-xbox-pc/SMJRHT Dropbox: http://db.tt/8qVS35lo
At the beginning of the game there are some copyright agreements for Nvidia so this game is more than likely optimized for most of their cards. Pezz is right about the video cards tweaking tools not showing accurate frames (strange?) and yes fraps does give the accurate readings of the game. So far I like it and as Semitop kinda said, it's the usual Max Payne but with way better graphics and deeper story (and I do mean deep).
The videos are the usual 60 fps and ingame I'm getting between 25-60 fps depending on the area I'm in and the amount of activities in an area. Might be my processor causing the fps jumps but it's rare so I can work with it till I get my new board and other parts.
Some Screenshots:
Settings:
Ingame:
Android Crew - HTC One X+
PC Specs - Motherboard: Asus Maximus Gene V | Processor: Intel Core i5-3570K @ 3.40GHz(3.80GHz turbo) | Memory: 2x 4gig Corsair Vengeance DDR3 1600 | Video Card: EVGA GeForce GTX 560 SC(1 GB) | Monitors: Asus 24" HD LED+Dell 17" | Xfire ID --> Powpow90
Nice Fps even though you not maxed. If you want to see your fps drop enable MSAA.
Quality nice either way, I would def play at those settings.
I wont be able to max it on my 6970 either. I should get better fps with 2GB of video ram though.
I am gonna buy this game in a week or two. Very excited for this game, like everyone else I know.
I know the fps represented weren't correct... I may not be pezz... however I am not that uninformed. I would be a mad man to think I was actually getting 100+ fps... with my four year old card which was mid range back in its day... lol however it doesn't do badly at all.... its not the illustrious 60+ fps a man would dream of but its a respectable amount IMO.
Max settings (as far as i can get with my card)
Yuh won't know till yuh try dude. If you liked Max Payne 2 and GTA4 you'll definitely rate dis game.
@yung_hero - Dude, how your temps so high man lol?
Anyways, as long as your card supports pixel shader 3.0 and above this game will look good no matter how low you drop the settings.
@Pezz - I know better than to enable MSSA with juss one a these cards lol. Once I put texture to very high and si Max start itch in the background I revert same time. Hmm, I going try out dat Teselation mode and see what it does.
Planning on buying the full version too later on as the multiplayer might be interesting.
