Results 1 to 2 of 2
Thread: winff econversion problem
    Feb 2012
    198
    Country
    Jamaica
    Default winff econversion problem
    today i was trying to convert a video with winff but kept getting errors each time i try
    Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/125) -> 23.98 (24000/1001)
    Input #0, matroska, from '/home/glenford/Downloads/filename.mkv':
      Metadata:
        doctype         : matroska
      Duration: 00:22:36.48, start: 0.000000, bitrate: 384 kb/s
        Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
        Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
        Stream #0.2(eng): Audio: aac, 48000 Hz, stereo, s16
    Unknown encoder 'libmp3lame'
    Press Enter to Continue
    http://randomteck.blogspot.com--check out my blog i try to discuss all tech related stuff
    6,126
    Country
    Jamaica
    1. Do you have the encoder libmp3lame installed?
    2. Is the version of winff the current version?
    3. What distro are you using?
    One method I use for converting matroska videos is the following script:
    #!/bin/sh
    INPUT=$1
    OUTPUT=$2
    mplayer "$INPUT" -ao pcm:fast:file=audio.wav -vc null -vo null
    mencoder "$INPUT" \
        -ffourcc divx \
        -ovc lavc -lavcopts vcodec=mpeg4:vhq:vbitrate=9800 \
        -audiofile audio.wav \
        -oac mp3lame -lameopts vbr=3 \
        -slang eng \
        -sws 2 -vf scale=720:576 \
        -o "$OUTPUT"
    rm -f audio.wav
    make sure you have mencoder and mplayer installed before running the above.
    SHANTI II - Ubuntu 13.04 64bit Desktop
    HP Pav G60-236US 3GB RAM Laptop, Ubuntu 13.04 64bit and Win7 Home
    Changes to posting in Classifieds
