If you're not getting what you should then most likely you have congestion in your area - maybe a load of people torrenting - or some issue otherwise on your line. You should call if you not getting what you should and speak with Tech Support and not just the customer service people. Get a ticket number for your issue and press it. If you not getting your speeds you should also get a rebate after the issue is resolved.
Supposed to be a 20Mb connection so 15+ not bad - and it's shared with my phones and mine and my wife machine and laptops.
