WTF is Windows?!?!?!? #thatisall
"my name is drae and i'm now an ubuntu convert"
is it me or am i imagining the bugs affecting me. anybody else experiencing the same ?
What bugs are you experiencing? The only problem I've with 12.04 is flashplayer crashing at times, but I figure this has more to do with adobe than ubuntu.
1) my keyboard is going on and off when i try to type so typing takes longer than it ought to . how do i know its ubuntu and not the keyboard i dual booted ubuntu along with windows 7 home premium and it works flawlesly in windows no problems ther whatsoever.
2) after i enter login details it freezes on that scren for a couple seconds(i think i might have done something wrong tha cause that to happen)
can someone confirm if Adobe CS5 or above works in this new build (obviously not natively) but via some emulation app or sumn
Re: 1) Unless you have some exquisite hardware, your keyboard should work as keyboard drivers are pretty much generic. Maybe something is wrong with your installation or your drivers.
Re: 2) Are you using unity-2d or 3d? If your gpu driver is not efficient you can experience some stuttering. Unfortunately, GPU drivers under linux are in a sad state. If your hardware can manage and your driver is sufficient, then the problem might again be your installation.
Maybe you upgraded from another version to 12.04? Usually, a clean install works best.
To ascertain if your installation is the problem, you can run a fresh copy from your flash drive to see if your keyboard works properly. The stuttering after login should be fixed in a fresh install. Don't know what you can do about it otherwise.
after a lot of consideration i just threw it on my 2TB drive last night
have never had good experience with 64 bit versions of Ubuntu, but omg my desktop has never performed this well ...it feels as if it's been woken up
now....im considering moving it to my 250GB drive and lopping Windows 7, as much as i liked it, out of the equation altogether.
>>Insert something witty here<<
