Results 1 to 9 of 9
Thread: Help Need with Javascript
    May 2010
    3,821
    Exclamation Help Need with Javascript
    Need help writing an array in Javascript.
    I need to create an array of size 20, in order to populate the array i have to do some addition.
    The values in slots [0] and [1] will be added and saved in slot [2], then slot [1] and [2] will be added to fill slot [3].
    This is what I have so far
    <script type="text/javascript">
    var myArray = new Array(20);
    myArray[0] = "2";
    myArray[1] = "1";
     for (var i = 0; i < myArray.length-1; i++)
       for (var j = 1; j < myArray.length-1; j++)
         for (var x = 2; x < myArray.length; x++)
         myArray[x] = myArray[i] + myArray[j];
    document.write( +myArray[x] );
    </script>
    CLICK-> Online Gamer Tags ** Job - Senior Dynamics 365 Consultant ** CLICK-> Surface Pro 4 128GB || DESKTOP-> IF THE TRUTH HURTS CLOSE THE THREAD
    If being a nerd means I make more money than you by just walking into a room, while still having a wife and social life... then it SUCKS To Be YOU !
    13,140
    29
    Haven't tested this and I haven't coded in javascript in a while so I am a bit rusty. But see if this will work.
    myArray[0] = "2";
    myArray[1] = "1";
    var i = 0;
    var j = 1;
        document.write(myArray[x]);
        i++;
        j++;
    </script>
    Anti-virus free since: August 2009
    May 2010
    3,821
    Quote Originally Posted by Arch_Angel View Post
    myArray[0] = "2";
    myArray[1] = "1";
    var i = 0;
    var j = 1;
        i++;
        j++;
    </script>
    just tried it but only gives a repetition of 21121211211212112121121121211211212112121121121211 21211211212112112121121211211212112112121121211211 212
    http://writecodeonline.com/javascript/
    13,140
    29
    Quote Originally Posted by King_Jay16 View Post
    Oops. Remove the quotes around the 2 and the 1. What javascript does with the values depends on how you store the values.
    You stored them as strings (the quotes around them), so when you try to add them, javascript puts them together to get 21.
    Remove the quotes and it will treat them as numbers.
    myArray[0] = 2;
    myArray[1] = 1;
    var i = 0;
    var j = 1;
        i++;
        j++;
    </script>
    May 2010
    3,821
    myArray[0] = 2;
    myArray[1] = 1;
    var i = 0;
    var j = 1;
        i++;
        j++;
    </script>
    Thanks!!!
    i figured out another way as well
    myArray[0] = "2";
    myArray[1] = "1";
    for (var i = 2; i < myArray.length-1; i++)
       myArray[i] = parseInt(myArray[i-1]) + parseInt(myArray[i-2]);
       document.write( +myArray[i] + ','  );
    </script>
    Thanks again... first time with Javascript so was aplying C/C++/C# knowledge...
    OT: We need a rep system here!!!
    13,140
    29
    Thanks!!!
    Yes that will work, but you're making extra calls to the function parseInt(), to convert the string to an integer.
    Instead, just remove the quotes around the 2 and the 1 and you wouldn't have to use parseInt(). Javascript will treat it as an integer.
    myArray[0] = 2;
    myArray[1] = 1;
    myArray[i] = myArray[i-1] + myArray[i-2];
    In a small script like this, the small overhead of extra calls to parseInt() when it's not needed, won't make a huge difference. But better start coding efficiently now instead of later when your page starts to take some time to load.
    May 2010
    3,821
    myArray[0] = 2;
    myArray[1] = 1;
    i agree with you on that, thank you!!
    Dec 2011
    7
    Default Fibonacci sequence
    Looks like you're trying to generate Fibonacci's Sequence. You could try the following code I cobbled together. Its a cleaner implementation with the algorithm contained within a function:
    // define Fibonacci function
    function fibonacci(length) {
        if (length < 2) throw new Error("length must be greater than or equal to 2");
        var sequence = [1,1]; // declare and initialize an array
        var i = 2;
        while(i < length){
            sequence.push(sequence[i-2] + sequence[i-1]);
            i++;
        return sequence;
    // generate an array with the first 20 numbers in the Fibonacci sequence
    var fib_20 = fibonacci(20);
    document.write(fib_20);
    I posted this code up on jsdo.it. So you can try it out for yourself at the following link : Fibonacci Sequence
    May 2010
    3,821
    Quote Originally Posted by xegnma View Post
        var i = 2;
        while(i < length){
            i++;
        return sequence;
    Yup that is what I am generating, thanks for the additional post
