Results 1 to 4 of 4
Thread: Blackberry LCD problem
    Dec 2011
    4
    Country
    Jamaica
    Exclamation Blackberry LCD problem
    Have a tour 9630 here, every time i start up the phone screen is white everything else is functional. When i plug in the phone and do a battery a pull it works perfectly then it may start to glitch all i do is pres the lock button and it works ok again if i take it off the charger and move the phone a lil it goes to white screen. One tech said its a screen but im not sure
    could it be? If you know the fix and you are able to do at a reasonable price email me hustlazweare@yahoo.com wont be here all the time
    Thanks
    Ask me, If cant do it ill find a way. I need motivation to help me to help you to get everyone Rich!
    Jul 2009
    135
    Country
    United States
    i'd change the screen
    3,823
    Country
    Jamaica
    Ensure there was no moisture damage. Get some 90% alcohol and clean the contacts for the display connector on the board and screen. If you still have issues you could try a different OS/firmware. Failing those then a screen change may be in order.
    We never know too much that we can't learn. Unfortunately most Jamaicans are about "hurry come up" and swatting than actually learning....
    Apr 2008
    1,181
    Country
    Jamaica
    do the above, backup stuff and reflash firmware, if all else fails then you need a screen replacement.
    ATI RADEON HD 5450 2GB 2048MB DDR3 PCI-E --- AMD PHENOM 2 X4 --- 2 TERRA X3 HD's ---1 TERRA X2 HD's--- ASROCK N68-VS3 UCC --- 700WATT POWER Q --- 8GiGS MEMORY OCZ DDR3 --- ATI ALL IN WONDER TV CARD --- DUAL DISPLAY SAMSUNG 32 INCH --- VIZIO SURROUND SOUND SYSTEM -----TRIPLE BOOT [MAC OSX HACKINTOSH, WINDOWS 7 ETERNITY, WINDOWS 8 PROFFESIONAL EDITION]
