Results 1 to 10 of 17
Thread: help with seting up xampp
    May 2004
    525
    Default help with seting up xampp
    I have a new installation of xampp on my machine. I all my website are popping up errors that once worked perfectly. I think it has something to with error message setting. I tried playing around by changing the setting but i cant seem to find the right combination for the settings. Any idea how to fix this?
    "...men are that they might have joy."
    Nephi
    Feb 2008
    717
    11
    What's the error message that you are receiving?
    Did you take turn off friendly messages in Internet option?
    May 2004
    525
    I cant recall the messages but it has to do with how variable are checked for example if($_POST['var'] != "") causes an error also all opening tags that dont have "<?php" causes an error. some of my opeing tags are simply "<?"
    Nephi
    Feb 2008
    717
    11
    I do not have much experiences with xampp as it was a pain that's why i used wamp server instead.
    From the error you describe, its doesn't seem like its from xampp
    3,068
    Error messages are important. You will need to fix those errors eventually. especially if you plan to upload the website. But a temporary fix is to reduce the error level of you php.ini. Find you php.ini file and go to the Error handling and logging. You will see lots of text there, read it and set the "error_reporting = E_ALL | E_STRICT" or one of the other setting that are described.
    Dec 2005
    343
    In your php.ini file (C:\xampp\php\php.ini <== Default location)
    In line 516 of mine, I set the following:
    error_reporting = E_ALL & ~E_DEPRECATED
    If you want to really get rid of the errors, then you can turn errors off.
    In line 533
    display_errors = Off
    Check out WP Spartans and Dredix
    3,068
    turning errors off is a bad idea
    Dec 2005
    343
    I use the following to show me some errors
    error_reporting = E_ALL & ~E_NOTICE
    Not as heavy as the E_STRICT option which shows everything, even show functions and other calls which have been depreciated.
    Sep 2011
    16
    get website hosting for 24.95 per year at mandevillehosting.info
    Oct 2002
    1,986
    18
    Quote Originally Posted by dwih2007 View Post
    suh how this help the man now
