Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: Here's a C problem
  1. #31
    Mar 2004
    123
    Felt a little idle in the day, plus I'm a bit early for work so...
    Was searching the net and met up on this challenge. There are a few others out there but...
    I gave this one a shot, now lets see who else will try.
    There is no wrong or right, only consequencies to action
    "It is the duty of man to make his knowledge so complete in life, so as to make it impossible for any other to take advantage of him" - Marcus Garvey
  2. #32
    1,905
    21
    I am up for the challenge, long time me looking for something to sharpen up on, cause I am dusty on my looping, pointers, and other algorithms, coding in general.
  3. #33
    Jan 2005
    3,151
    lol the problem specified would be a simple one to solve in c under unix with the aid of lex and yacc.
    lex takes a ruleset and converts it into c code to parse input into tokens.
    yacc - yet another compiler creator, this tool takes a grammar and converts it to c code to parse it.
    lex isnt even needed for a program of this magnitude as the tokenset is so limited
    Updated versions to these apps would be flex and bison for those of you who use the newer linux distros.
    Reference: The dragon book.
  4. #34
    Mar 2004
    123
    I test my solution with these two files.
    flat.inp
    5
    0 7 8 1 4
    flat1.inp
    5
    2 9 10 3 6
    Created By:	TJRAK
    Title:		Flatten
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <conio.h>
    void movechips(int [], int, int);
    void main()
     FILE *indt;
     int chips[10];
     char getdata[20];
     char *tokenptr;
     int size,i =0,total =0,prpile;
     if ( (indt = fopen("flat.inp", "r"))==NULL)
    // if ( (indt = fopen("flat1.inp", "r"))==NULL)
     	printf("Could not open input file");
     else {
     	fscanf(indt, "%d", &size);
       while(!feof(indt)) {
       	fgets(getdata, 20, indt);
          }//end while
     fclose (indt);
     tokenptr = strtok(getdata, " ");
     while (tokenptr!=NULL) {
     	chips[i] = atoi(tokenptr);
     	tokenptr = strtok(NULL, " ");
     	i++;
     	} //end while loop
     for(i=0; i < size; i++)
     	total+=chips[i];
       prpile = total/size;
     	movechips(chips, size, prpile);
     }//end else not file open error
    //_^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^__^_
    //______________________________________________________________________________
    void movechips(int a[], int b, int pp)
        int key, success,i, temp[10], d;
        int count =0, pos = b, swap = 0, control = 0;
        FILE *indt;
        if ( (indt = fopen("flat.out", "w"))==NULL)
    	 	printf("Could not open output file");
    else{
          fseek(indt, 1, SEEK_SET);
     do{
    	for(i = control; i < b; i++){
       		success = 0;
       		key = (a[i]/pp)*2;  //determine the amount of chips to move
    		if(i == 0)		//check if current position is first pile
    			if(a[i] >= pp)	//check to see if more chips than allowed is on the pile
          			a[i] -= key;	//take off pile
    				a[i+1]+= key;	//add to pile on right
    				if(swap%2 == 0)
             			fprintf(indt, "\n%d %1d", i+1, key);
    				else
    					d = (b - (b-(i+1)));
              			fprintf(indt, "\n%d %1d", d, key);
    				count++;
    		if(i == (b-1))	//check if your at the last pile
    				a[i-1]+= key;	//add to pile on left
    				if(swap%2 == 0)
    				else
    				 count++;
    		if (i!=0 && i!= (b-1))
    			if(a[i] >= pp)
    				if(a[i]%pp == 0 && control == 1)
              			a[i]-= key;
    					a[i-1] += key/2;
    					a[i+1] += key/2;
    					if(swap%2 == 0)
             				fprintf(indt, "\n%d %1d", i+1, key/2);
    					else
              				fprintf(indt, "\n%d %1d", d, key/2);
    				else
             			a[i]-= key*2;
             			a[i-1] += key;
             			a[i+1] += key;
    					if(swap%2 == 0)
    					else
    				count ++;
    		for(int c = 0; c < b; c++)
           		if (a[c] == pp)
    				success++;
    			if (success == b)
    				break;
    	}//end of for i = control
    	if (success < b)
    		for(i = 0; i < b; i++)
    			temp[pos-1] = a[i];
      	 		pos--;
       		a = temp;
       		control = 1;
    		swap++;
    	else
    	break;
     } while (success < b);
       fseek(indt, 0, SEEK_SET);
       fprintf(indt, "%d\n", count);
       fclose (indt);
     }//end of else
    }//end function
  5. #35
    1,905
    21
    I needed more time so I did not look on your code. I have two approach but they are not complete Every time I think I got it, I don't... cho I dream pon it last night, tonight again.
