Page 102 of 168 FirstFirst ... 25292100101102103104112152 ... LastLast
Results 1,011 to 1,020 of 1677
Thread: Dragon Nest
  1. #1011
    Aug 2011
    288
    w
    Quote Originally Posted by Ωmega View Post
    U frass enuh, If a even 25 jelly mi affi mek the sacrifice and buy because mi naa mek even one + pon none of my epics without jelly on it. Nope...no way. Ordinary jewels cost too much to go try mek one from scratch.
    A_A you dont NEED physical attacks as a moonlord...you can go all magic tree without a problem. Just that most people prefer a hybrid, but even then...the bulk of your skills should be from the wave tree
    well u see the thing is blaxx jellies dnt sell in the market on NA so mi affi try a thing if it break a so just farm n buy a next 1... the nx i bought the other was to get my perm costume might buy another 25k and get some jellies and stamps
  2. #1012
    Mar 2007
    2,542
    Quote Originally Posted by r0dZz View Post
    w
    OOOH....u know i thought jellies were available in trade house on NA. I see wat u goin thru now. Which perma costume u buy? the thigh high watsitnot sinting? I want one too but I wana wait to see which other perma gona come out. I see some decent ones in the other versions dat look much much better than the ones available now
    Black by popular demand
    Ω
    Asus G73JH 17.3" - Core i7 740QM|6GB DDR3 1333| ATI Mobility Radeon 5870 1GB| 640GB HDD
  3. #1013
    13,270
    35
    I know. I taking the skills to the right of the skill tree, the magic attacks. Most of the guides keep the physical attacks at lvl 1 and hybrid builds increase a few of them. I think I am more leaning to the hybrid build tho.
    doc craft ur weaps in balance cuz moonlord is a mag and phys char mostly mag doe but u need phys att to
    So you saying I shouldn't have gone with intellect weapons and gear?
    I'll keep in mind that I need both STR, INT, Phys Att and Mag Att on my gear and blues. Having phys att and mag att for blues at the same time on gears is rare. And expensive to boot if I find dem.
  4. #1014
    Mar 2007
    2,542
    Quote Originally Posted by Arch_Angel View Post
    If you going hybrid then you will have to sacrifice one plate so you have both BEAR and MAGICIAN. You need both for hybrid. Also....as a hybrid...you still have a primary tree, and if your primary tree is magic, then intellect is your best bet. You will be a hybrid with a slant toward magic, so you should build accordingly. Also, going epic gear is better because epic gears give Str AND Int when you craft them as well as Vitality. Sounds expensive yes, but you chose hybrid and its usually very expensive to go hybrid so happy farming
    edit: yow roddzz/migz....the cerb bonus stats go up as u enhance the gear? meaning....if u start out with bonus 800HP...with each + u add to it, does the bonus stat increase as well?
    Ω
  5. #1015
    Aug 2011
    288
    nope craft it in balance cuz u gna need both mag n phys att.
    lol no the bonus stats remain the same blaxx. that wud b awesum tho lol
  6. #1016
    4,918
    24
    Quote Originally Posted by zelink View Post
    Omega iv seen people and vids say it does recover hp, rem sea is not fully translated like the other dragon nests. I have seen my pally recover hp before.
    Yuh a mix up League with DN now man, though I wish Warriors had a skill for this cause they need it. Is not regen yuh regen, a muss heal or healing relic.
    Anyways I can si how dam expensive it is to plus up a epic now star. Bought a hammer in Trade House and had about 40 rough rubies, which I made into Ordinary Rubies with more than 20 Medium Water and all I get so far is this :
    When it nuh fail it drop to +3 how annoying:
    Uploaded with ImageShack.us
    Current Android - OnePlus 7T Pro
    PC Specs - Motherboard: Asus PRIME B560-PLUS | Processor: Intel Core i5-11600K (stock) | Memory: 32 gigs Corsair Vengeance DDR4@3200mhz | Video Card: ASUS ROG Strix GeForce RTX 4070 (OC Edition) | Monitor: ASUS TUF Gaming 27" 2K Monitor | Steam ID -> Powpow
  7. #1017
    Mar 2007
    2,542
    Quote Originally Posted by Powpow View Post
    When it nuh fail it drop to +3 how annoying:s[/URL]
    at +4 its better than ur +8
    Ω
  8. #1018
    13,270
    35
    Wouldn't it be better than his +8 at any + he has on the epic? The + doesn't increase the white stats, only the green ones, the Enhancement Potential. Correct me if I am wrong.
  9. #1019
    Aug 2011
    288
    unuh a do nuh mino runs tonight?
  10. #1020
    Nov 2008
    737
    3k def nest come like ntn now mi ready for monticore nest!
    CPU ATHLON II X4 635 3.4GHZ OC
    RAM 16GB DDR3 1600
    GFX ASUS HD 4870 1GB dark knight
    MOBO ASRock M3A785GXH/128M
