Results 1 to 6 of 6
Thread: help with isNaN
    May 2004
    522
    Default help with isNaN
    I have this simple check but for some reason javascript is not seeing the var as a number even when it is a number. This is the code:
    if(isNaN(usagePos1)){
    Process(usagePos1);
    } else {
    alert(usagePos1+" is not a numeric value! Please enter a numeric value!");
    return false;
    usagePos1 is actually passed as a parameter from a split()
    Any ideas?
    "...men are that they might have joy."
    Nephi
    13,157
    29
    As far I know, the result from a split() is always an array and passing an array to the isNaN() function would most likely give you some incorrect results. Might want to loop through the array usagePos1, passing each value through isNaN().
    Anti-virus free since: August 2009
    Jan 2007
    162
    first line should be : if(!isNaN(usagePos1)) since isNaN returns false when usagePos1 is a number.
    May 2004
    522
    Thank you all so much for your replies. I will look into it.
    Nephi
    13,157
    29
    Quote Originally Posted by hassanvoyeau View Post
    Oh yeah, that's right. isNaN is already in the negative. If isNaN is true, that means it's Not-a-Number. If it's false, that mean's it IS a number. That one slipped me. But my excuse is, it was 4am in the morning. :P
    May 2004
    522
    Thank you all it works perfectly.
    Nephi
